i ill be replace my pump tomorrow and just wanted so advice on the job. my buddy said his was a real pain. thanks guys
power streeing pump
Re: power streeing pump
It's really not that bad.
- Use flare wrenches for the hose nuts, they strip easily with regular wrenches
- Rent the power steering pulley puller from autozone or checkers. Not a standard 3 jar puller, which will bend up the pulley
- Make sure the o-rings are seated nice so you don't get leaks. Use a little bit of ps fluid to lube themDrivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
