power streeing pump - FirebirdV6.com/CamaroV6.com Message Board
power streeing pump
  • power streeing pump
    i ill be replace my pump tomorrow and just wanted so advice on the job. my buddy said his was a real pain. thanks guys
    Re: power streeing pump
    i think the big thing is just to make sure you bleed the air out of the system
      Pull the old one off...and be sure to put the new one in its place.
        It's really not that bad.
        - Use flare wrenches for the hose nuts, they strip easily with regular wrenches
        - Rent the power steering pulley puller from autozone or checkers. Not a standard 3 jar puller, which will bend up the pulley
        - Make sure the o-rings are seated nice so you don't get leaks. Use a little bit of ps fluid to lube them
        2001 Pewter Firebird Y87, M5
        Go Sabres!
