I just got my rear brakes swaped from drums to disk now my brakes are grinding like crazy, I did install the shims what else could cause the grinding noise?
HELP! REAR disk brakes grinding
Re: HELP! REAR disk brakes grinding
Originally posted by some_punkI just got my rear brakes swaped from drums to disk now my brakes are grinding like crazy, I did install the shims what else could cause the grinding noise?Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by FirebirdGTIs the rotor rubbing on the PAB? Maybe you didn't need the shim? Did you measure before you installed the shim?
