at least from strano. rears are $64 each fronts are $67. great price in my opinion. but i cant wait until december. i need these in like 2 weeks or less. anyone know where else i can get these bad boys from...and preferably with a warranty? thanks
brembo stock oe blanks are on backorder...
Re: brembo stock oe blanks are on backorder...
Originally posted by TheGr8Schlotzkywhat's the difference between brembo blanks and oem blanks?
stock replacement blanks are like $23 a piece
OEM just means that it is supposed to be the same as stock in fit, form and function.
But if you don't know where the blank came from it could be junk.
I had Brembo blanks, and didn't like them. My next set will be Baer.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
tirerack is on backorder 10-12 weeks i cant wait that long unless i wish to not stop one day soon.
any suggestions to a brand that can compare in price/durability?
ive heard too many bad things to go with any cross drilled or slotted rotors (despite how much i would like the look of them)
Originally posted by FirebirdGTOEM just means that it is supposed to be the same as stock in fit, form and function.
why didnt you like the brembo blanks? what do you have on your car now?
Get the ones Strano sourced instead. Honestly, with a good install (torque wrench, proper cleaning and prep) no half decent disc should warp. I've turned cheap imported discs blue from the heat of road racing and never had a warping problem.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
Originally posted by NkTyson06why didnt you like the brembo blanks? what do you have on your car now?
The front warped. AC Delco DuraStop on the front, Brembo blanks still on the rear.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
