i just installed one of my new drilled/slotted rotors (driver rear to be exact) along with new pads and shims, but after i got it all together and put the wheel back on there is an extremely loud whine coming from them. to narrow it down, it only does it in a forward gear, not reverse. i havent went over 5 mph because it just sounds like something bad will happen if i do. i know theres supposed to be some noise from new pads, but this is way too loud.
suggestions? i thought i might of over torqued the calliper bolts, but i took them off and re-torqued and it was still the same.
1999 v6 Camaro M5 Automatic to Manual converted Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
They are R1 concepts rotors and pads made specifically for my car. yes i did use a c-clamp to compress the cylinder, i think your right meaty, but like i said i tried loosening up the calliper.. idk
one thing i didnt mention was when i took off the stock rotor, it was very hard to get off, and i hit it with a rubber mallet a couple of times, then i forgot that i had the e-brake on (lol), so i hope that didnt mess up anything.
fixed it! had the parking brake out of whack, and that was the problem. i think this was actually answered in another thread, but i didnt understand it at the time.
1 day ago
