Abs Inop Help!!!! - FirebirdV6.com/CamaroV6.com Message Board
Abs Inop Help!!!!
  • Abs Inop Help!!!!
    so ive had my abs inop light on for a while and idk whats going or how to fix it i already disconnect the sensor on the front calipers and cleaned with electric cleaner but nothign and idk what to look for in the rear od how do i go on to chek what else is wrong do you gusy think maybe my relay is bad, and i need to fix it beacause im a hard braker and the brakes locked up on me last week, i sure would appreciate any help this problemis is gettin on my nerves thanxs:)
    Re: Abs Inop Help!!!!
    My light is on too. I had mine taken to the shop and looked at and I forget exactly what it is called but I think they said that I had to replace my sensors and it was going to be expensive so Im just going to have to learn to start breaking earlier and keep my distance in the rain.
      The ABS inop light will also come on if you have a brake light out, check those. Remember the center one has two bulbs.
      Hope that helps.
        Hope that helps.
        Originally posted by kala
        TEAM BLACK!!!
        parting her out
          Yes, Opie-IN is right about the 3rd brake light and ABS inop light. But this is just an indicator they built (kinda ad-hoc) into the system, but the ABS system should still work in this condition.
          If you are locking up when you brake, the system will have a definite fault.
