How hard is it to change out the front control arm bushings in a 95 camaro 3.4 L? Also what parts do I need to buy to do this and how much are the parts?? link please..
Front Bushings
Re: Front Bushings
Originally posted by jsviking08How hard is it to change out the front control arm bushings in a 95 camaro 3.4 L? Also what parts do I need to buy to do this and how much are the parts?? link please..
If memory serves me right you will have to remove the stut/spring assembly and that can be a PITA. You will need a strut compressor tool, but normally you can get that on loan from your local auto store. After the wheels and strut/spring assembly is out you will be free to remove the UCA and replace the bushing.
Diagram
If you can take all that apart and put it back together your good to go. I would say a 6 on a 1-10.
The strut mount will most likely be fused or rusted to the strut, I had to cut the shaft on mine. If it is not you will have to have a specail socket to turn the nut without turning the shaft. You will most likely need the following parts:- Strut
- Strut Mount
- UCA
- UCA Bushings
Gmpartsdirect.com is a good place to go.Last edited by PewterBird; 11-29-2007, 09:34 PM.
Re: Front Bushings
Diagram
- Strut Mount
- UCA
- UCA Bushings
OUR CARS DO NOT HAVE STRUTS! :mad:
http://forum.camarov6.com/showthread.php?t=75984Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
