i got some sweet new drilled rotors for an early xmas gift and i cant for the life of me get the rear rotoers off. there isnt like a bolt on there for the rears is there? they should be just like the fronts right? cause i have been trying to hammer them off for a half hour
removing rear rooters
Abbott long tubes,homemade true duals,slp ram air,whisper lid,eibach springs,kyb shocks,BMR subframe connectors, BMR LCA reloc brackets,BMR LCAs. T-top/manual convertedTags: None
Re: removing rear rooters
i believe i had the same problem, its initially hard to get the rotors o ff the axle but its easy after that. make sure your e brake isn't on too.1999 v6 Camaro M5
Automatic to Manual converted
Pacesetter Headers, 2.5" Custom True Duals with X-Pipe and Magnaflow Bullet Muffers,
!cat, Intake, 3.42's with LSD, MSD Wires, Drilled/Slotted Rotors, Hurst Short Shifter, Tuned PCM
Once you remove the calipers, they should pull right off, if not like said above their are probably the clips on there.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by Black98FivespeedDidn't even think about that, make sure the e-brake isn't on, that would definitely prevent the rotor from coming off...
yeah, i think that was my problem actually. haha1999 v6 Camaro M5
