please help (brakes) - FirebirdV6.com/CamaroV6.com Message Board
  • please help (brakes)
    Hi
    Can someone help me?
    I am doing a change in my camaro
    Is a 3.8 1996 and I am installing the rear axle of a z28 96, discs with calipers posi... Change the entire shaft (The v6 has no rear discs)
    I would like to know if I should change something else to work properly
    I refer primarily to the brakes to work well
    thanks
    Re: please help (brakes)
    If you already have the whole rear end with the calipers and rotors , you should have the brake lines with it and backing plates, if not you'll need them , the brake cables for the calipers, right and left. Also new brake pads since your in there , thats about it.
