S0o i took the car for alignment......n sure enough the guy is like...we need to change the inner tie rod.....well I came home n tried changing it my self...i managed to get the boot off.....the tie rod ends off.....but how do i take off the inner tie rod.....by the way iv got 95 3.4 v6!!! hellpppp
Inner tie r0d
Re: Inner tie r0d
get a long *** wrench and take it off.
i had to use one of those huge pipe wrenches to get mine off. They are loc tighted on
Re: Inner tie r0d
you dont even really need to take off the tie rod ends to get the inner rods off.
take off that rubber boot, and then there should be this little white cover over where the ball join connects. push that little plastic cover back and you can see where it twist off.
do you have the new inner rod? if you do you can use it for reference
Re: Inner tie r0d
go to autozone they usually stock the part. but here is a pretty good picture
http://shbox.com/1/innertierod.jpg
