Ok so I was following my friends earlier today. One has a twin turbo 350Z and the other one has a turbocharged Civic. We were driving through the mountians and I could definitley out run the civic in the turns but on the straight aways they would take over. My brakes got really hot and at one point I could barely even stop. What can I do as far as upgrades go? I know I can buy a rear brake swap from drums to disk I could also buy the C5 conversion but that is really expensive. Does the Z28 have a lot larger rotors or what? How much does the rear brake swap help. What have others done to help their brakeing? I have done some searching and I just wanted to know what yall thought. Thanks.
Break Upgraded needed
Re: Break Upgraded needed
Originally posted by techsan23try drilled rotors on the front with performance pads & replace and adjust your rear shoes.
Slotted rotors are to wear the pad down faster, to help with braking. You will go through pads faster, but it will keep the pad clean.
But yes, look at a few different pads. See whats best.
I would'nt be so sure about that Trey. If I get accepted up here I will be going to this place a lot it was a lot of fun. I dont think it had a whloe lot to do with the fact that it was the mountians, there were not any major inclines or declines. There was this one straight away where I got going pretty fast and then I had to slow down a lot to make the sharp turn then there was a short straight away and When I hit the brakes again I just didnt want to stop.
Originally posted by elkindwI would'nt be so sure about that Trey. If I get accepted up here I will be going to this place a lot it was a lot of fun. I dont think it had a whloe lot to do with the fact that it was the mountians, there were not any major inclines or declines. There was this one straight away where I got going pretty fast and then I had to slow down a lot to make the sharp turn then there was a short straight away and When I hit the brakes again I just didnt want to stop.
What is the difference in size between the 94Z28 and the 94 V6 front rotors. I did some research and couldnt find the answer. I checked out lmperformance.com, Advance Auto Parts and SummitRacing. All I found was that one of the rotors was 10.9in. I think that was on the V6 but not sure.
Originally posted by bigbrian442Upgrade your front brakes to the 12" 98 and up units.Last edited by elkindw; 01-27-2008, 07:11 PM.
Originally posted by elkindwWhat is the difference in size between the 94Z28 and the 94 V6 front rotors. All I found was that one of the rotors was 10.9in. I think that was on the V6 but not sure.
None.
ALL 93-97 fronts have 10.9" rotors & single-piston calipers. V8's had 11.4" rear discs, V6's had drums - unless it was a Y87, then it also had the 11.4" rear discs.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by elkindwWhat all do I need for that? Do I need a new master cylinder what else? The 98 and up V6 has the same brakes as the Z28 right?
Spindles & calipers. Then any rotor/pad you want.
No, not a good idea as the car will now be biased to the front. The bigger bore 98+ master will just make it worse.
ALL 98-02 have the same brakes front and rear. V8 or V6 doesn't matter.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Re: Brake Upgrade needed
Originally posted by elkindwHow much does the rear brake swap help. What have others done to help their brakeing? I have done some searching and I just wanted to know what yall thought. Thanks.
Originally posted by FirebirdGTALL 98-02 have the same brakes front and rear. V8 or V6 doesn't matter.2002 Navy Blue Metallic Blue Firebird A4
Pure stock (Hey, just bought it 11/07)
