aight i have this problem and i dont know what to do,i took my camaro to get aligned and the guy told me that i was able to aligne the car but he coulndt get the steerting wheel straight so i took it back home and took the steerign wheel off and i found out that you cant fix from there either so my dad try to do it from the bottom of the car and nothing, what do you guys think i should do any help would be much appreciated thanxs
cant get it straight
Re: cant get it straight
To adjust the steering wheel, you need to adjust your outter tie-end rods, depending on which side your steering is off 11 o'clock or 1 o'clock. To adjust it for lets say, 11 o'clock you would move it "in" so many turns on the drivers side outter tie-end rod then do the same amount of turns going "out" on the passenger side tie-end rod. Also make sure you watch the steering wheel so it doesn't move on ya.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
a good alignment shop should be able to do that, where did you take it?
the guy probably just told you he couldnt do it because he didnt want to
