Steering thingy... - FirebirdV6.com/CamaroV6.com Message Board
Steering thingy...
  • Steering thingy...
    Over time I've dealt with this in both of my Camaros, but its starting to get annoying. The steering wheel or the k members arnt set right, because I have to hold the wheel to the right slightly to keep it straight. Nothing rattles, nothing shakes, the wheel just needs to be held at a different position than it should. Do help, please!
    I ate a bowl of fail this morning.
    Quarter Million Mile Club
    Re: Steering thingy...
    Now is the car pulling or is it that you the steering wheel isn't dead center?
    Is the road tilted?
    Have you aligned your car?
    Is one of you caliper piston stuck?
    Do you have different tires?
    Are your tire inflated correctly?
    Have you checked your bearing assembly?
    Are your tie rods worn?
    Post your alignment before and after measurments.
      New tie rods, new brakes, new tires, flat road...it just might be that the steering wheel isnt centered from a possible repair. How should I center it?
        Is the car pulling any? Or is it going straight but the steering wheel is off?
          straight and the steering wheel is off.
            if you never pulled the steering wheel of, then the steering wheel doesn't need to come off. You can adjust the position of the wheel by adjusting the tie rods. Loosen them and adjust them in or out...but I recommend taking it to a shop where they can laser align it.
            You said repairs...what repairs? Did you get into an accident?
              negative. Its quite possible that something was done to the car that affected the steering before I bought it, or my mechanics didnt align it properly.
                I'd double check the alignment results...get a printout. It'll give you the intial settings and the aligned settings. Your machanic could have very well aligned the car but didn't align the wheel.
                  definatly check the alignment. thats your best bet
