Over time I've dealt with this in both of my Camaros, but its starting to get annoying. The steering wheel or the k members arnt set right, because I have to hold the wheel to the right slightly to keep it straight. Nothing rattles, nothing shakes, the wheel just needs to be held at a different position than it should. Do help, please!
Steering thingy...
Re: Steering thingy...
Now is the car pulling or is it that you the steering wheel isn't dead center?
Is the road tilted?
Have you aligned your car?
Is one of you caliper piston stuck?
Do you have different tires?
Are your tire inflated correctly?
Have you checked your bearing assembly?
Are your tie rods worn?
Post your alignment before and after measurments.
if you never pulled the steering wheel of, then the steering wheel doesn't need to come off. You can adjust the position of the wheel by adjusting the tie rods. Loosen them and adjust them in or out...but I recommend taking it to a shop where they can laser align it.
You said repairs...what repairs? Did you get into an accident?
definatly check the alignment. thats your best betHeady Navy Blue Metalic<br />Heady Catback Flowmasters<br />Heady Bilstien HDs, PAnhard rod, LCAs,SFCs<br />NGK\'s and MSD Wires, K&N flowin + Smooth Bellow<br />Y87 3800 GT Performance.<br />I love the way this car makes turns!<br /><br />1989 black Camoaro RS. R.I.P.
