So apparently i have a problem with my hand brake in my 3.4. When i release the had brake the red "brake" light is still on, a mechanic told me that it was because the had brake is about one click away from being fully released. He wanted to charge me $80 for the job. Any how, does anyone know how to adjust the hand brake?
Hand Brake issue
Re: Hand Brake issue
this happened on my 94 Bonneville I had before I got my Firebird. for some reason the E-brake light would stay on even when I hadn't engaged it. it freaked me out for a while cause I thought i was driving with it on, but it went away after 15 minutes of driving or so. it did this for about a month or so, and then just stopped and never did it again. hope you figure out what the problem is...
1999 Firebird Y87/W68
actually yesterday this happened to me... on my way home. so i tried to switch it off and turn the engine again.. but it wont start... thought it was a dead battery charged it for like 3 hours.. still wont start... figured out it was just the connection of my battery cables...:slap:
Horsepower is how fast you hit the Minivan... Torque is how far you take the Minivan with you... :wavey:
Originally posted by Firehawk N WvMine were rusted also and the I had to cut my nuts off .
Remove your center console and you will see there is a little metal tab on the ebrake handle. When you pull up on the handle it looses connection and dash light comes on. You put it all the way down and makes connection so light on dash goes out. Maybe your tab got bound up somehow.Originally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
Originally posted by iZZZ!how do you remove the automatics, knob?
shift into 1st
on the shift knob, facing the dash you will see a little "staple" going into the knob.
you just need to get that staple out.
i used a small screwdriver.
if its the first time coming out, it might take a little hammering to get it under there to wedge it out.
once the staples out, just pull the knob off.
thats all!
finally got home to sj, i was bored and tired form the drive (in the 2000)
so i went to the 95, the one with the problem, started the car, released the hand brake, , pressed the button and pulled on it really hard a few time, and the problem was fixed. thanx guys
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
