Please help, disc brake conversion questions - FirebirdV6.com/CamaroV6.com Message Board
  • Please help, disc brake conversion questions
    Hi, im new to the site but not to Camaros. I have a 1997 rs camaro that I want to change the drum brakes on the rear to a disc brake setup. My cousin has the rear end out of a fourth gen f-body that still has the rotors, calipers, and brake line on it. I do not know if it came out of a newer v6 or lt1 camaro. All i know is its out of a camaro. But anyways, I want to know what all will I have to do to swap the disc brakes onto my car. Will it be simple like just changing the backing plates put on the rotor/caliper? Will I have to run new brake lines? Will it affect my traction control sensor or ebrake in any way? Any help would be greatly appreciated as I only have a couple days before he junks it. Oh, a complete swap is not possible due to the fact that the yoke bearing is no good. I just want to know if I can transfer what I need onto the rear end that is already under the car. Thanks.
    Trey.
    Re: Please help, disc brake conversion questions
    The parts need to have the same antilock system your car has, 3 channel or 4 channel. Is the ABS sensor in the housing above the ring gear or at each wheel?
      I havent had a chance to check it yet. Anyone else have any input?
        98- newer cars have the same brakes regardless of v6 or v8. The only difference is the 3 or 4 channel ABS.
          yea but the brake lines are diffrent on 97 and earlier to the 98 +
          Originally posted by kala
          TEAM BLACK!!!
          parting her out
