well on a full take i can get 300 to 310 miles before fill up on my stock tires 235/55/16 now that i changed my tires 245/50/16 in the front and 255/50/16 in the rear on an full take i get now 270 to 280 so what gives? thanks guys
haveing wider tires lose mpg?
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
Re: haveing wider tires lose mpg?
Also possible they're under inflated, which means more friction, which means more work to move the car, which means more gas used, which means worst mileage :P. Check the pressure.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
the tire pressure is fine i always check it :) so should i go back to my stock tire width? i was think of 235/50/16 in the front and 245/50/16 in the rear will this help or just 235/50/16 all round thanks again guys2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
i got good handling i got a stut tower a 35mm sway bar and im try to get a 19mm i also got Eibach lowering springs that i be putting on soon so handling looks good :) for looks i think they will be looking more at my cme then how wide my tires are lol gas is not cheap2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
i rember when i use to get 375-400 to the tank back in the days lol when my car was stock now the max i get is 320 on a full tank and stock tires. my mods are whisper lid, k&n filter ,pos 3.73 ,aulminum driveshaft, catco high flow cat, magnaflow 2.5 cat back, 1.9 rockers with ls6 spring and ls1 retainers, hpp3, hypertec 160 t-stat, msd coil pack with msd wires2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
its just weird that im losing mpg then i guess ill play around with my tires and see what happen i would no why im loseing mpg2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
yeah im wondering too2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by Mr. Logger View PostNo it doesn't ^
