Well I got my subframe connectors in on saturday. I think I welded the drivers side a little too close to the lip. It's rubbing actually. Scared the ever living **** outta me when I hit a bump and it sounded like a weld cracked. A dumbass mistake. I'm gonna bend the lip out a bit and go hit a bump and hope the sound doesn't happen again. And hope the sfc is still on there. I'll get pics up asap. ****tiest welds I've ever done. The undercoating isn't pretty either. The hardest part was getting the bolt back through the LCAs. Other than that it was easy as hell. And having them for jack points is totally worth it. Yeah like I said, pictures asap.
Subframe connectors
Re: Subframe connectors
I had it completely loaded yes, all the tires were on blocks. There's no way I could have welded it with the car directly on the ground.. If you did when you installed yours I give you props and you have to be the smallest guy in the world cause I'm no incredible hulk myself and there was no way I was fitting under it unless it was raised.
TEAM C6V6
