what size should the inside measurement be?
heater hose question
Re: heater hose question
Originally posted by Smoke Panther View Postif you're asking what size hose to get, use a 5/8th hose08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
yeah if you jack the car all the way up in the air, and let the rear end hang down, you should be able to just pull the spring out
Originally posted by Meatyshells View Postyeah if you jack the car all the way up in the air, and let the rear end hang down, you should be able to just pull the spring out
Originally posted by deftons56 View PostI had to let the rear hang down and unbolt the shock to get my springs out when putting the new eibachs in....and just did the heater hose mod when switching out rearends. Now my car sits 5" off the ground behind the front wheel and 6" infront of the rear wheel. Hopefully I still don't scrape on stuff ( I didn't really before the HH mod)08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
