I don't relly know a lot about suspention, but I'm sick of mine being all messed up in the back. When I have a full car I get a loud thud noize every time I hit a bump, and I can push up and down on my spoiler and move the car 3 or 4 inches up and down so I know something needs to be replaced, I just don't know what. I wanna avoid the shop bacause I wanna save money to put into my motor hopefully. What should I do?
Need help
Re: Need help
rear shocks are very easy to replace. Just take out the panels on either side of the hatch area, and fold down the back seat. Then fold the carpet over the back and on either side you'll see a white foam piece, just pop that off and the shock bolts are right there. Bottom is pretty self explanatory.
Here's fronts: http://ls1howto.com/index.php?article=6
Re: Need help
and do you guys think ill be able to tell the difference between this shock:
http://www.car-stuff.com/carparts/ch...ets331221.html
and this shock?
http://www.car-stuff.com/carparts/ch...oets58671.html
