lca relocation brackets - FirebirdV6.com/CamaroV6.com Message Board
  • lca relocation brackets
    Does anyone have a step by step walk through as to how to install these? and how hard it is...I dont think it can be that hard...
    Re: lca relocation brackets
    not hard at all, a couple bolts to remove. and replace.
    http://www.bowtiev6.com/
      on a stock height car would you still go with the lowest setting?
        Why would you need relocation brackets for stock height?
        TEAM C6V6
          Yes on the rightest setting. Relo's can improve traction on a stock ride, but you don't want to add too much of an angle. Are you getting the bolt on ones or the weld ons?
          Lounge Moderator
            ahh I see. I always thought they were pretty much just for when you lower the car to keep the control arms purpose intact.
            TEAM C6V6
              The manufacture of mine said the 2" hole on stock would help greatly with wheel hop. They also said the 3" hole on stock was bad bad bad... but I forget why. Lowered gets the 3" to correct the angle. Sumptin' like that anyway.
              Lounge Moderator
                Hmmmm so I might just get a pair of them now.. Since I'm keeping my car stock height for the strip. **** I think I will, I'll put em in during the lca install :)
                TEAM C6V6
                  They claim a tenth off your 60'.
                  Lounge Moderator
                    mine has 2 holes...its the bolt on ones...I'm putting them on to help combat squatting...these and new shocks...I'm dead hooking with a full bolt on 96 camaro with 3.90 gears in the back....I didnt think this was possible....
                      Anywho... download this. Bolt on LCA relo directions.
                      http://www.armediaproduction.com/bonemaro/lca.doc
                      Lounge Moderator
                        Just put it where the lca's are straight with the car(ground), not at a angle. I used the first seting and it seems to work for mine.
                          I thought the goal was to get a slight downward angle towards the rear to force the tire to the ground.
                          Lounge Moderator
                            you will want to use the lowest hole on them
                              with a stock ride height? this wont have a negative effect on my handling correct?
