"A word of warning putting the LCA's at there lowest setting (on an unlowered car) will make the car loose, so before really cornering the car hard, you might want to feel out how the car handles after the mod."
so once you put them on a setting say the lowest one...do you have to go through almost the whole installation again to change holes? or would it now be as simple as popping out that bolt, sliding the arm up then screwing it back in?...so essentially a 5 minute job?
I don't know about 5 minutes, but yeah, pretty much as simple as popping out the bolt and moving it up..
