lca relocation brackets - FirebirdV6.com/CamaroV6.com Message Board
  • #16
    Re: lca relocation brackets
    Originally posted by LETZRIDE View Post
    with a stock ride height? this wont have a negative effect on my handling correct?
    I read that it will, yes. Let me see if I can find that write up.
    Lounge Moderator
    • #17
      This is what I read, for what it's worth.
      "A word of warning putting the LCA's at there lowest setting (on an unlowered car) will make the car loose, so before really cornering the car hard, you might want to feel out how the car handles after the mod."
      Lounge Moderator
      • #18
        so once you put them on a setting say the lowest one...do you have to go through almost the whole installation again to change holes? or would it now be as simple as popping out that bolt, sliding the arm up then screwing it back in?...so essentially a 5 minute job?
        • #19
          I don't know about 5 minutes, but yeah, pretty much as simple as popping out the bolt and moving it up..
          Lounge Moderator
          • #20
            In THEORY, this is true. But in practice, it might take a little work. Getting the holes to line up perfectly took a little time.
            http://www.cardomain.com/memberpage/799659
            • #21
              I hear the holes can be a Bee Eye Itch, but I say, just get a bigger hammer.
              Lounge Moderator
              • #22
                all you have to do is raise/lower the rear untill the bolts line up
                • #23
                  in theory. assuming everything is perfectly squared off.
                  • #24
                    my umi bolt-in brackets didn't line up at all. I had to do some "massaging" of a few holes to get it bolted in.
