drum to disc conversion - FirebirdV6.com/CamaroV6.com Message Board
  • drum to disc conversion
    has anyone done a drum to disc conversion on their f-body? i'm looking to do it this summer and any advice on parts or anything would be great
    Re: drum to disc conversion
    I have , follow the write ups below in the write up section.
      http://forum.camarov6.com/showthread.php?t=63738
      :):tup:
        I'd tell you to search on here and look at switching out the whole rearend and get diffrent gears, LSD, and rear calipers all for about 250.
        There are tons of threads on this but heres one thats not too old and says what all you'll need.
        http://forum.camarov6.com/showthread.php?t=87102
        Originally posted by kala
        I'll have buttsecks with Richard Simmons!
        TEAM BLACK!!!
        parting her out
          u make it sound like its so easy to find - I have been looking for some time now and have not come across a whole rearend for anyting close to that pice with the option like that - i would gladly pay 250 for a rear with posi rear,3.42's, and disk brakes.
          1994 3.4L DSG Camaro
          Comp Cam 260h w/ 1.6 rockers, J&M STB, UMI 3pt SFC's, Spohn RCA's + Adj. PHR, KYB AGX Shocks, PS Headers, Cutout, Posi Rear w/3.42's, Aluminum DS, Wings West Body Kit, SS Hood/Spoiler, 17" TT2's 9.5/11" 275/315's, 5% tint
            try the v8 forums?
              I didn't do the drum to disc conversion, but I did do the 93-97 to 98-02 disc brake conversion....If you do convert your drum brakes I would highly reccommend going straight to the larger style brakes...
              Y87 Package
              MANUAL CONVERTED, Pro 5.0 Shifter
              Pacesetters, Magnaflow Cat, Cutout, Flowmaster
              MOGOB APPROVED!
              BONE APPROVED!
              VANBIBBER APPROVED!
              KRISTEN APPROVED!
              Vice Prez.
              Team Black...TEAM EMO
              Come on kids! Get a Calendar!
                Originally posted by t-topV6 View Post
                try the v8 forums?
                do that or call junk yards. Where are you located? shipping can be pricey but you could drive a few hundred miles and pick one up for 50 bucks in gas or so.
                TEAM BLACK!!!
                parting her out
                  I assume you mean the FRONT brakes?
                  Raven
                    Yes, and IIRC you can upgrade the rear brakes to 98 - 02 as well, though it's not much of an upgrade. Something on the order of gaining .6" in size, and upgrading to an aluminum caliper if you go 98 - 02, but if you're going to change it, might as well change it to the better option, right? He already has front disc brakes, so of course that wouldn't be a drum to disc conversion, but upgrading to the 98 - 02 style system obviously has it advantages with a much larger rotor, and two-piston aluminum calipers.
                    Y87 Package
                    MOGOB APPROVED!
                    BONE APPROVED!
                    VANBIBBER APPROVED!
                    KRISTEN APPROVED!
                    Vice Prez.
                      Doing the rear drum to disc isn't expensive if you look around main things are backing plates, calipers, parking brake lines. Brake pads I would get new along with rotors. I think I spent total along with the new parts $200, also draining the rear and new fuild and gasket so maybe $230 total. If you get the whole diff. , Your still looking for the parking brake lines, pads and rotors= another $150 or so at least.
                        i just want to do the drum to disc conversion and not swap the whole rear end. i already put in 3.42 gears and a lsd.
                        the main reason i want to do the swap is because drums just flat out suck in the rain and they make my car look cheap.
                        finding all the parts is gonna be a pain but i'm definitely gonna try it this summer after i do some other stuff. i'm planning on pulling the heads off and getting them machined and replacing the rear main oil seal because it has a small leak that drips right on the down pipe
                        thanks for the help!
                          I am parting a car out and if you want just the conversion stuff I could make a deal with you. What part of VA are you in?
                          TEAM BLACK!!!
                          parting her out
                            sounds good to me, i'm in the Richmond area, what car are you parting out? i'm looking for "newish" parts for the conversion
                              You really don't need new parts just rotors and brake pads. Calipers (no more than 75,000 miles) Parking brake cables(no more than 100,000) and backing plates( doesn't matter as along as their intact, heavy steel there). Thats just me though, and what I did and their still working good.
