squeeling brakes - FirebirdV6.com/CamaroV6.com Message Board
squeeling brakes
  • squeeling brakes
    my brakes squeel every stop I make, and its getting past annoying...I have almost brand new rotors and pads that I put in early january so its not old brakes. What causes them to squeel if they arent old?
    1999 Firebird Y87/W68
    Re: squeeling brakes
    Cheap pads or overheating the pads.
      cheap pads then...cause they do it at the very start even. well, time to replace em eh?
        dont brakes squeal if you dont spray that disc brake silence stuff on them? i havent had it happen to me, but i remember being told that. maybe they didnt do that?
          i change my own brakes, and ive never sprayed that stuff on them haha. one of my friends tried that brake quiet stuff on his car and they stopped for about a week and started again.
            Couldn't hurt to try it. Is it all four corners squeaking?
            1996 Chevrolet Camaro
            1995 Buick Park Avenue Ultra
            --Appearance Moderator--
              i know someone who had the same problem with a truck and it was because he put heavy duty brake pads on it that were to hard for the stock rotors. maybe you just put the wrong type of brake pads on or they are the wrong type of material
                possibly. ill borrow that break quiet from that guy and give them a shot, and no its not all four wheels, just the front and rear drivers side.
                  also start simple and use some brakleen.
                  #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
                    that brake quiet stuff isnt for the rotor itself, its for like the back of the pad, for when brakes are squeaking against the brackets and stuff like that.
                      brakes squeal because they are cheap, get some of that anti squeal stuff and put them on
                      when you see a good pair of brakes you see how different the padding is between the pad and the pistons
                        Make sure the pads you get have shims attached to the back
