After trying to swap in a 32mm front sway bar/bushings/endlinks this weekend, I was reminded on why I've shyed away from car repairs/upgrades. Halfway into trying to unbolt the endlinks, I realize I was just spinning the bolt as I cranked away on the nut, lol. I didn't have the upper body strength to loosen the nut and bolt simultaneously.
I tried a little WD40, but no luck. I did manage to tighten everything back up.
Looks like another visit to Meineke...unless I can talk my neighbor to give me a hand.
I hear ya , I tried changing my front brake lines to stainless and I couldn't get the old ones apart. So now I have to wait until I can get some help to do them.
I live in upstate ny...I'll try some different penetrating sprays, unless you want to drive up and help me install it! :)
Although I don't think this is typical, I sprayed my endlinks with PB Blaster, let it sit overnight and after loosening with a wrench, literally took the bolts off by hand.
2 days ago
