Brake Pads too thick??? - FirebirdV6.com/CamaroV6.com Message Board
  • Brake Pads too thick???
    I just tried putting some Pro Stop brake pads on the front left and the caliper wouldn't easily get up to the top bolt when the new ones were in. I finally used some leverage and got it there but then the rotor wouldn't turn at all. Are the pads too thick and has anyone had a problem like this before? I haven't until now...
    2000 M5 SILVER FIREBIRD<br />*Flowmaster 80<br />*K&N air filter<br />*SLP LCAs<br />*Fast Toys CAI
    Re: Brake Pads too thick???
    You need to get a "C" clamp and slowly compress the caliper in. It will then self adjust once you put pressure on brakes
    Originally posted by kala
    I'll have buttsecks with Richard Simmons!
    TEAM BLACK!!!
    parting her out
      Or you could buy a brake caliper compressor from advance for like $10. either way does the same thing, the same way.
      Y87 Package
      MANUAL CONVERTED, Pro 5.0 Shifter
      Pacesetters, Magnaflow Cat, Cutout, Flowmaster
      MOGOB APPROVED!
      BONE APPROVED!
      VANBIBBER APPROVED!
      KRISTEN APPROVED!
      Vice Prez.
      Team Black...TEAM EMO
      Come on kids! Get a Calendar!
        I compressed the two brake pistons all the way. I don't see how the caliper can be compressed when it is one solid piece... The problem is that the outer brake pad is too thick and that caused the caliper to not be able to slide over far enough in towards the car so that the upper bolt holes would line up. I am going to get some OEM pads tomorrow to see if they work.
        Thanks for the replies.
          What year car?
          Y87 Package
          MOGOB APPROVED!
          BONE APPROVED!
          VANBIBBER APPROVED!
          KRISTEN APPROVED!
          Vice Prez.
            pro stop pads are cheap i hate them get some hawks
              i hated hawk.
              all i will use on all my cars is duralast. and yes that is what i use on my camaro for drag racing too. they are perfect pads
              WAWA-A-HOLIC
                I like bendix pads.
                Y87 Package
                MOGOB APPROVED!
                BONE APPROVED!
                VANBIBBER APPROVED!
                KRISTEN APPROVED!
                Vice Prez.
                  You actually have to compress the piston into the caliper.
                    Originally posted by kristen View Post
                    i hated hawk.
                    I second that. Duralast makes good parts.
                      By far, the best pads I've used is factory AC Delco pads. I'm putting new front pads on my Trans Am to next week replace the ORIGINAL factory AC Delco pads. The car has 77k miles and God knows how many passes down the track. Never glazed or sqealed once. Find an aftermarket pad that can do that.
                      -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
                        Compress the pistons back into the calipers. I had this EXACT same problem after I put mine back on. Did this, and everything was fine. That's your problem.
