Brake Conversion - FirebirdV6.com/CamaroV6.com Message Board
Brake Conversion
  • Brake Conversion
    alright. I converted my 96 Y87 front disc brakes (the little 10.7" rotors) to the bigger and beefier 11.9" 98+ rotors, which involved a steering knuckle upgrade...all the good stuff. So my question is, when you upgrade the brakes, is there a parameter in the PCM's binary file that has to be changed for the ABS to still work? Or is it simply the wheel speed sensor? I'm stumped here. I can't figure out which one of these it is. Do I need a 98+ brake module?
    Y87 Package
    MOGOB APPROVED!
    BONE APPROVED!
    VANBIBBER APPROVED!
    KRISTEN APPROVED!
    Vice Prez.
    Team Black...TEAM EMO
    Come on kids! Get a Calendar!
    Re: Brake Conversion
    Nothing in the PCM pertaining to ABS. Did you scan for the ABS code? That kinda makes it simple.
      Well if I had a scanner that interfaced with the ABS module, i'd do that. Any ideas otherwise?
      Y87 Package
      MOGOB APPROVED!
      BONE APPROVED!
      VANBIBBER APPROVED!
      KRISTEN APPROVED!
      Vice Prez.
        Go pay someone to scan it.
          Everything works fine. You don't have to do anything.
          Raven
            He is asking why his ABS light is on after the conversion. Wanting people to guess so he can replace parts.
              Actually I'd call it asking people if they've experienced similar issues to find out what course of action to take.
              I don't replace parts on pointless whims.
              Y87 Package
              MOGOB APPROVED!
              BONE APPROVED!
              VANBIBBER APPROVED!
              KRISTEN APPROVED!
              Vice Prez.
                go to your local autozone, I believe they can scan ABS systems.. but if not, it doesnt hurt to call and ask...
                if anything, take it to your dealer. cant be all that much to scan, but again, asking them the same question doesnt cost a thing, and they might be able to direct you in the right direction..
                Archer
                MISC: 01 parts. Some interior, T top kit, seats etc.
                http://forum.camarov6.com/showthread.php?t=95347
                  How simple is it to have it scanned? Anything else is a guess. This is the second thread you asked this question in, no one replied in your first. Maybe someone with a crystal ball will chime in give you the codes causing your ABS light.
                  I say it's one of the following codes'
                  Generic ABS codes
                  C0000 - Vehicle Speed Information Circuit Malfunction C0035 - Left Front Wheel Speed Circuit Malfunction
                  C0040 - Right Front Wheel Speed Circuit Malfunction
                  C0041 - Right Front Wheel Speed Sensor Circuit Range/Performance (EBCM)
                  C0045 - Left Rear Wheel Speed Circuit Malfunction
                  C0046 - Left Rear Wheel Speed Sensor Circuit Range/Performance (EBCM)
                  C0050 - Right Rear Wheel Speed Circuit Malfunction
                  C0051 - LF Wheel Speed Sensor Circuit Range/Performance (EBCM)
                  C0060 - Left Front ABS Solenoid #1 Circuit Malfunction
                  C0065 - Left Front ABS Solenoid #2 Circuit Malfunction
                  C0070 - Right Front ABS Solenoid #1 Circuit Malfunction
                  C0075 - Right Front ABS Solenoid #2 Circuit Malfunction
                  C0080 - Left Rear ABS Solenoid #1 Circuit Malfunction
                  C0085 - Left Rear ABS Solenoid #2 Circuit Malfunction
                  C0090 - Right Rear ABS Solenoid #1 Circuit Malfunction
                  C0095 - Right Rear ABS Solenoid #2 Circuit Malfunction
                  C0110 - Pump Motor Circuit Malfunction
                  C0121 - Valve Relay Circuit Malfunction
                  C0128 - Low Brake Fluid Circuit Low
                  C0141 - Left TCS Solenoid #1 Circuit Malfunction
                  C0146 - Left TCS Solenoid #2 Circuit Malfunction
                  C0151 - Right TCS Solenoid #1 Circuit Malfunction
                  C0156 - Right TCS Solenoid #2 Circuit Malfunction
                  C0161 - ABS/TCS Brake Switch Circuit Malfunction
                  C0221 - Right Front Wheel Speed Sensor Circuit Open
                  C0222 - Right Front Wheel Speed Signal Missing
                  C0223 - Right Front Wheel Speed Signal Erratic
                  C0225 - Left Front Wheel Speed Sensor Circuit Open
                  C0226 - Left Front Wheel Speed Signal Missing
                  C0227 - Left Front Wheel Speed Signal Erratic
                  C0229 - Drop Out of Front Wheel Speed Signals
                  C0235 - Rear Wheel Speed Signal Circuit Open
                  C0236 - Rear Wheel Speed Signal Circuit Missing
                  C0237 - Rear Wheel Speed Signal Erratic
                  C0238 - Wheel Speed Mismatch
                  C0241 - EBCM Control Valve Circuit
                  C0245 - Wheel Speed Sensor Frequency Error
                  C0254 - EBCM Control Valve Circuit
                  C0265 - EBCM Relay Circuit
                  C0266 - EBCM Relay Circuit
                  C0267 - Pump Motor Circuit Open/Shorted
                  C0268 - Pump Motor Circuit Open/Shorted
                  C0269 - Excessive Dump/Isolation Time
                  C0271 - EBCM Malfunction
                  C0272 - EBCM Malfunction
                  C0273 - EBCM Malfunction
                  C0274 - Excessive Dump/Isolation Time
                  C0279 - Powertrain Configuration Not Valid
                  C0281 - Brake Switch Circuit
                  C0283 - Traction Switch Shorted to Ground
                  C0284 - EBCM Malfunction
                  C0286 - ABS Indicator Lamp Circuit Shorted to B+
                  C0287 - Delivered Torque Circuit
                  C0288 - Brake Warning Lamp Circuit Shorted to B+
                  C0290 - Lost Communications With PCM
                  C0292 - Lost Communications With PCM
                  C0291 - Lost Communications With BCM
                  C0297 - Powertrain Configuration Data Not Received
                  C0298 - Powertrain Indicated Traction Control Malfunction
                  C0300 - Rear Speed Sensor Malfunction
                  C0305 - Front Speed Sensor Malfunction
                  C0306 - Motor A or B Circuit
                  C0308 - Motor A/B Circuit Low
                  C0309 - Motor A/B Circuit High
                  C0310 - Motor A/B Circuit Open
                  C0315 - Motor Ground Circuit Open
                  C0321 - Transfer Case Lock Circuit
                  C0323 - T-Case Lock Circuit Low
                  C0324 - T-Case Lock Circuit High
                  C0327 - Encoder Circuit Malfunction
                  C0357 - Park Switch Circuit High
                  C0359 - Four Wheel Drive Low Range (4LO) Discrete Output Circuit
                  C0362 - 4LO Discrete Output Circuit High
                  C0367 - Front Axle Control Circuit High
                  C0374 - General System Malfunction
                  C0376 - Front/Rear Shaft Speed Mismatch
                  C0379 - Front Axle System
                  C0387 - Unable to Perform Shift
                  C0472 - Steering Handwheel Speed Sensor Signal V Low
                  C0473 - Steering Handwheel Speed Sensor Signal V High
                  C0495 - EVO Tracking Error
                  C0498 - Steering Assist Control Actuator Feed Circuit Low
                  C0499 - Steering Assist Control Solenoid Feed Circuit High
                  C0503 - Steering Assist Control Solenoid Return Circuit Low
                  C0504 - Steering Assist Control Solenoid Return Circuit High
                  C0550 - ECU Malfunction - internal write / checksum malfunction
                  C0559 - EEPROM Checksum Error
                  C0563 - Calibration ROM Checksum Error
                  C0577 - Left Front Solenoid Circuit Low
                  C0578 - Left Front Solenoid Circuit High
                  C0579 - Left Front Solenoid Circuit Open
                  C0582 - Right Front Solenoid Circuit Low
                  C0583 - Right Front Solenoid Circuit High
                  C0584 - Right Front Solenoid Circuit Open
                  C0587 - Left Rear Solenoid Circuit Low
                  C0588 - Left Rear Solenoid Circuit High
                  C0589 - Left Rear Solenoid Circuit Open
                  C0592 - Right Rear Solenoid Circuit Low
                  C0593 - Right Rear Solenoid Circuit High
                  C0594 - Right Rear Solenoid Circuit Open
                  C0611 - VIN Information Error
                  C0615 - Left Front Position Sensor Malfunction
                  C0620 - Right Front Position Sensor Malfunction
                  C0625 - Left Rear Position Sensor Malfunction
                  C0628 - Level Control Position Sensor Circuit High
                  C0630 - Right Rear Position Sensor Malfunction
                  C0635 - Left Front Normal Force Circuit Malfunction
                  C0638 - Left Front Normal Force Circuit High
                  C0640 - Right Front Normal Force Circuit Malfunction
                  C0643 - Right Front Normal Force Circuit High
                  C0655 - Level Control Compressor Relay Malfunction
                  C0657 - Level Control Compressor Circuit Low
                  C0658 - Level Control Compressor Circuit High
                  C0660 - Level Control Exhaust Valve Circuit Malfunction
                  C0662 - Level Control Exhaust Valve Circuit Low
                  C0663 - Level Control Exhaust Valve Circuit High
                  C0665 - Chassis Pitch Signal Circuit
                  C0690 - Damper Control Relay Circuit Malfunction
                  C0691 - Damper Control Relay Circuit Range
                  C0693 - Damper Control Relay Circuit High
                  C0695 - Position Sensor Overcurrent (8 volt supply)
                  C0696 - Position Sensor Overcurrent (5 volt supply)
                  C0710 - Steering Position Signal Malfunction
                  C0750 - Tire Pressure Monitor (TPM) system sensor not transmitting
                  C0755 - Tire Pressure Monitor (TPM) system sensor not transmitting
                  C0760 - Tire Pressure Monitor (TPM) system sensor not transmitting
                  C0765 - Tire Pressure Monitor (TPM) system sensor not transmitting
                  C0800 - Device Power #1 Circuit Malfunction
                  C0896 - Electronic Suspension Control (ESC) voltage is outside the normal range of 9 to 15.5 volts
                    Or these.
                    GM specific ABS codes
                    C1211 - ABS Indicator Lamp Circuit Malfunction
                    C1214 - System Relay Contact or Coil Circuit Open
                    C1217 - Pump Motor Shorted to Ground
                    C1218 - Pump Motor Circuit Shorted to Voltage or Motor Ground Open
                    C1221 - Left Front Wheel Speed Sensor Input Signal is 0
                    C1222 - Right Front Wheel Speed Sensor Input Signal is 0
                    C1223 - Left Rear Wheel Speed Sensor Input Signal is 0
                    C1224 - Right Rear Wheel Speed Sensor Input Signal is 0
                    C1225 - Left Front Excessive Wheel Speed Variation
                    C1226 - Right Front Excessive Wheel Speed Variation
                    C1227 - Left Rear Excessive Wheel Speed Variation
                    C1228 - Right Rear Excessive Wheel Speed Variation
                    C1232 - Left Front Wheel Speed Circuit Open or Shorted
                    C1233 - Right Front Wheel Speed Circuit Open or Shorted
                    C1234 - Left Rear Wheel Speed Circuit Open or Shorted
                    C1235 - Right Rear Wheel Speed Circuit Open or Shorted
                    C1236 - Low System Supply Voltage
                    C1237 - High System Supply Voltage
                    C1238 - Brake Thermal Model Exceeded
                    C1241 - Variable Effort Steering Circuit Malfunction
                    C1242 - Pump Motor Circuit Open
                    C1243 - BPMV Pump Motor Stalled
                    C1244 - Powertrain Indicated Engine Drag Control Malfunction
                    C1246 - Brake Lining Wear Circuit Open
                    C1248 - EBCM Turned the Red Brake Warning Indicator On
                    C1251 - RSS Indicated Malfunction
                    C1252 - Left Front Normal Force Malfunction
                    C1253 - Right Front Normal Force Malfunction
                    C1254 - Abnormal Shutdown Detected
                    C1255 - EBCM Internal Malfunction
                    C1256 - EBCM Internal Malfunction
                    C1261 - Left Front Inlet Valve Solenoid Malfunction
                    C1262 - Left Front Outlet Valve Solenoid Malfunction
                    C1263 - Right Front Inlet Valve Solenoid Malfunction
                    C1264 - Right Front Outlet Valve Solenoid Malfunction
                    C1265 - Left Rear Inlet Valve Solenoid Malfunction
                    C1266 - Left Rear Outlet Valve Solenoid Malfunction
                    C1267 - Right Rear Inlet Valve Solenoid Malfunction
                    C1268 - Right Rear Outlet Valve Solenoid Malfunction
                    C1271 - Left Front TCS Master Cylinder Isolation Valve Malfunction
                    C1272 - Left Front TCS Prime Valve Malfunction
                    C1273 - Right Front TCS Master Cylinder Isolation Valve Malfunction
                    C1274 - Right Front TCS Prime Valve Malfunction
                    C1276 - Delivered Torque Signal Circuit Malfunction
                    C1277 - Requested Torque Signal Circuit Malfunction
                    C1278 - TCS Temporarily Inhibited By PCM
                    C1281 - VSES Sensors Uncorrelated
                    C1282 - Yaw Rate Sensor Bias Circuit Malfunction
                    C1283 - Excessive Time to Center Steering
                    C1284 - Lateral Accelerometer Sensor Bias Malfunction
                    C1285 - Lateral Accelerometer Sensor Circuit Malfunction
                    C1286 - Steering Sensor Bias Malfunction
                    C1287 - Steering Sensor Rate Malfunction
                    C1288 - Steering Sensor Circuit Malfunction
                    C1291 - Open Brake Lamp Switch Contacts During Deceleration
                    C1292 - Brake Fluid Pressure Sensor Circuit
                    C1293 - Code C1291 Set in Previous Ignition Cycle
                    C1294 - Brake Lamp Switch Circuit Always Active
                    C1295 - Brake Lamp Switch Circuit Open
                    C1296 - Brake Fluid Pressure Sensor Circuit
                    C1297 - PCM Indicated Brake Extended Travel Switch Failure
                    C1298 - PCM Class 2 Serial Data Link Malfunction
                    C1326 - Battery Out of Range
                    C1650 - RSS Control Module Fault
                    C1658 - RSS Control Module Calibration Fault
                    C1710 - Left Front Damper Actuator Short Circuit to Battery
                    C1711 - Left Front Damper Actuator Short Circuit to Ground
                    C1712 - Left Front Damper Actuator Open Circuit
                    C1715 - Right Front Damper Actuator Short Circuit to Battery
                    C1716 - Right Front Damper Actuator Short Circuit to Ground
                    C1717 - Right Front Damper Actuator Open Circuit
                    C1720 - Left Rear Damper Actuator Short Circuit to Battery
                    C1721 - Left Rear Damper Actuator Short Circuit to Ground
                    C1722 - Left Rear Damper Actuator Open Circuit
                    C1725 - Right Rear Damper Actuator Short Circuit to Battery
                    C1726 - Right Rear Damper Actuator Short Circuit to Ground
                    C1727 - Right Rear Damper Actuator Open Circuit
                    C1735 - Compressor Relay Short to Battery
                    C1736 - Compressor Relay Short to GND/Open Circuit
                    C1737 - Exhaust Solenoid Valve Short to Battery
                    C1738 - Exhaust Solenoid Valve Short to GND
                    C1743 - Speed Signal Fault
                    C1744 - Lift/Dive Signal Discrete Fault
                    C1760 - Left Front Position Sensor Input Fault
                    C1761 - Right Front Position Sensor Input Fault
                    C1762 - Left Rear Position Sensor Input Fault
                    C1763 - Right Rear Position Sensor Input Fault
                    C1768 - Position Sensor Supply Fault
                    C1780 - Loss of Steering Position Signal
                    C1782 - ICCS2 DL Left Output Short Circuit to Bat
                    C1783 - ICCS2 DL Left Output Short Circuit to GND
                    C1784 - ICCS2 DL Right Output Short Circuit to Bat
                    C1785 - ICCS2 DL Right Output Short Circuit to GND
                    C1786 - Damper Control Relay Fault
                    C1787 - Damper Control Relay Short to GND
                    C1788 - Damper Control Relay Short to Bat
                      Thank you, that helps.
                      Y87 Package
                      MOGOB APPROVED!
                      BONE APPROVED!
                      VANBIBBER APPROVED!
                      KRISTEN APPROVED!
                      Vice Prez.
                        Nothing in the original post says that!
                        "is there a parameter in the PCM's binary file that has to be changed for the ABS to still work?"
                        Raven
                          I read it as, he has done the conversion and the ABS doesn't work. He wants to know if the PCM needs a file changed or it's a sensor causing the ABS not to work. Either way the answer is to SCAN it for ABS codes, Not ask people what went bad on their ABS.
