:tup:ANyone have one? I tried to search with not much luck.
Need good writeup on changing brake fluid
1999 Bright Red A4 3.8L V6 Camaro
http://www.cardomain.com/ride/2589653
http://www.myspace.com/jhonathanwTags: None
Re: Need good writeup on changing brake fluid
Is there a reason why you want to change your brake fluid?
Basically you will need to remove the fluid from the master cylinder (syphon or suction bulb is easiest way), fill it with clean fluid and then bleed all 4 brakes until clean fluid runs out. Remember to fill the master cylinder several times while doing this or you will let air into the system. If you have a reverse bleeding kit then it would be even easier but most poeple don't have one.
Yeah it is nasty. Thanks for the tips though.1999 Bright Red A4 3.8L V6 Camaro
Originally posted by nascar24jd View PostIs there a reason why you want to change your brake fluid?
Good tip on doing the brake fluid , also safer. Not letting air into the system.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by nascar24jd View PostVery true, I forgot to mention that. Without the cap on you will have quite the mess...
paint is in showroom condition, i almost had a heart attack when i saw brake fluid dripping on the ground, thankfully it didnt eat the paint away or anything
engine bay has never been cleaned, and has the original windshield washer fluid, everyone always asks if it has been repainted because they have never seen a car that old with stock paint as good as that
edit, does that engine look familiar ;)
and sorry for thread crapping
edit2* heres a pretty good guide, just to make up for my thread crapping http://www.ehow.com/how_2111457_chan...ake-fluid.html
not f body specific, but it helpsLast edited by cam98aro; 06-12-2008, 07:59 AM.
No worries1999 Bright Red A4 3.8L V6 Camaro
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
