I have these tires. They are 235s. What should I be keeping them filled at? Currently I have been keeping them at 30 psi. Is that too low?
BFG Traction TA
Re: BFG Traction TA
I always do mine around 35psi, gives them alittle room to expand when they are heating up, from driving. Have had zero problems, you'll also get better gas milage.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: BFG Traction TA
Most tires show a MAX psi on the side of them. This does not mean that you should run the tire at that pressure. Tire pressures for any vehicle should always be set to the pressures indicated on the tire placard on the door. The max pressure is put on the tire so someone does not try to put it on a vehicle that recommends more air pressure than it is capable of.
With that being said, running the air pressure at 30psi or 35 psi is fine, and I doubt you'll see any difference.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Re: BFG Traction TA
Originally posted by zpwn06 View Postreally? and didn't take them off after the first time? good show
Originally posted by TheGr8Schlotzky View PostThis isn't a "recommend me some new tires" thread.
30-35psi will do just fine.
Re: BFG Traction TA
Originally posted by cam98aro View Postconsidering they were good tires
:stp:-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
