removing rotors - FirebirdV6.com/CamaroV6.com Message Board
removing rotors
  • removing rotors
    changing out the brakes and rotors. there is this little washer like spiral cap thing on the rotor that is really hard to take off, is there any easy way of taking it off? do i need to put them back on?
    Re: removing rotors
    those are pushnuts, just try to get a flat blade screwdriver underneath it and break it off. you don't need to put them back on.
      Re: removing rotors
      I usually snip them with a pair of wire cutters. Again, no need to put them back on. They are installed on the assembly line to keep the rotors in place before the calipers are installed.
      -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
        Re: removing rotors
        /\ correct. good luck
        WAWA-A-HOLIC
          Re: removing rotors
          also, make sure oyu grease those caliper pins up nicely. It'll save you in the future
          Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
            Re: removing rotors
            pry with a scewdiver then clip with side cutters.
            -Y87
            Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
