almost ever since i got my car, ive noticed a lot of brake dust on the front rims, and it seems to be getting worse, when i put my car in neutral going down hills, it seems like its dragging a lot, and when i jack it up and spin the front wheels, you can hear them rubbing and turn a lot harder then they should Is it the calipers not releasing or something else? thanks
brake drag
Re: brake drag
I would recommend first taking both front calipers off and greasing the pins well. Make sure you use a proper silicone based grease. Go to a parts store and ask for some caliper pin grease, they should know what you need. The stuff I use is from Napa, part #765-1351-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
