Panhard Rod with no Lubrication? - FirebirdV6.com/CamaroV6.com Message Board
  • Panhard Rod with no Lubrication?
    Would it be alright to install a panhard bar and not grease it right away? It has the little plug things to hook up a grease gun to it but i dont know when i would be able to use one. (sorry if I'm not explaining it correctly, I don't know the technical terms)
    Pretty much, can I drive with no lubrication on the panhard rod for a little while. Thanks.
    Re: Panhard Rod with no Lubrication?
    hmm. i'd say it is prob pre done at the factory. I can be wrong though
    1997 Camaro LS1 RS
    1994 Camaro - Sold
    1999 Trans am Vert - Sold
    A Few Mods....
      hmm, what would be the worst thing to happen if it wasnt pre lubed.
        rust?
          polyurethane bushings are pretty noisy w/out grease. just run it thru a quick lube shop; if they do charge you it wont be much
            You won't need any lube if they are rubber bushings, poly, like said, will just be noisy.
            1996 Chevrolet Camaro
            1995 Buick Park Avenue Ultra
            --Appearance Moderator--
