I saw this while looking at the QA-1 coil spring setup I'm going to get on UMI's website, I have a poly trans mount right now and those who did theirs probably had to do like I did and notch or prolong the existing hole so it would bolt up correctly. Also putting in rubber bushings to make up for the height difference(thanks to IGRA's write up). But looking at it, I think it would work on ours, I went from a 96' Camaro M5 to A4 and used my same crossmember for the A4 tranny. If I get time I'll see what mine measures from the mounting holes to the bolt opening for the trans mount. Take a look, let me know what you think:
