STUPID QUESTION by me (again) - FirebirdV6.com/CamaroV6.com Message Board
  • STUPID QUESTION by me (again)
    is 1.8`` drop to much for a camaro??? or is it ok?,,,i will be using stock shox
    Re: STUPID QUESTION by me (again)
    do you mean physically OK or opinionated OK ?
    personally i wouldn't want to drop the car more than 1" or 1 1/2 "
    but in terms of how far is too far in a technical standpoint idk.
    btw, the only stupid question is the one NOT asked.
    i've had some pretty dumb questions in my time. ;)
      I dropped mine 2+ inches with a body kit and I have no problems at all. There's this one steep, curvy, peaking driveway I frequent (I'll have to get a pic) that you would think stock would have trouble, and I go right in without a scrape. My apartment complex is speed bump central and those are not problem either. Alignment bays / racks, no problem. Jacks, I carry 2 small cuts of 2x8 in the back to roll up on (but the jack was an issue at factory height with the kit). Jiffy Lube's floor lift was the closest I've have to an issue, but even then, no problems... See, look how low I'm talking...
      Lounge Moderator
        you should definitely replace your shocks if youre going to be lowering that much.
        <a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
          Yeah, buy FKids adjustables.
          Lounge Moderator
            what if i use the stock shox???
              Idunno... I installed an entirely new system when I did my suspension, so I can't say with certainty what just springs would do. Surely not handle as well, but I don't foresee unusual clearance issues. What are the road conditions like at your location?
              Are the ground clearances of the 3.4 and 3.8 models the same? Never thought about that.
              Lounge Moderator
                road condition??? pretty bad,,,but i know where to drive,,,,,,
                  As crazy as this sounds, I actually took small strips of metal and clipped them to my kit to simulate the post lowering clearance of the lowest components, then drove normally to see if I could hit them. I did not.
                  Lounge Moderator
                    Stock shocks will not work right with a 1.8" drop,
                    you need to buy new shocks, or have a shop revalve the old ones (good luck finding someone to do it)
                    1.8" is not too much of a drop, the eibach drag kit lowers exactly that much, but stock shocks can't handle it...
                    And as bone said, I have brand new KYB Adjustables for Sale at a great deal...
                    Y87 Package
                    MANUAL CONVERTED, Pro 5.0 Shifter
                    Pacesetters, Magnaflow Cat, Cutout, Flowmaster
                    MOGOB APPROVED!
                    BONE APPROVED!
                    VANBIBBER APPROVED!
                    KRISTEN APPROVED!
                    Vice Prez.
                    Team Black...TEAM EMO
                    Come on kids! Get a Calendar!
                      Yes, his price is a great deal for these KYB's. If there's any possible way you can scoop these up, do it. You will love the control and ability to dial in your ride.
                      Lounge Moderator
                        hey guys,,,,,,went to an partstore and saw a thing that you can clamp your stock springs and lower your car,,,,is that good??? or dangerous???
                          It's stupid!
                          TEAM C6V6
                            ...and dangerously doesn't work. The first hard bump you hit will knock it off and.or strip it to pieces.
                            Lounge Moderator
                              lol definitely not a good idea. Stock F-body Springs have certain spring rates dialed in and clamping them together would just go and mess them up and pretty sure you're handling to.
