Going above 50 and I get a rumbling noise from the rear - FirebirdV6.com/CamaroV6.com Message Board
  • Going above 50 and I get a rumbling noise from the rear
    Like the title says, I get a rumbling noise from the rear when I'm going above 50, also above 50 the car starts to shake as well. I think it's just the tires are out of balance. Anyone have any other suggestions on what it is?
    Re: Going above 50 and I get a rumbling noise from the rear
    sounds right to me. either that or they are out of alignment
    1999 Firebird Y87/W68
      Thanks, I just didnt want no surprises when I took her to have the wheels done.
        I second that , out of balance.
          Yeah, but if you're rear tires are out of alignment on a solid rear axle car, I think there are bigger problems to worry about...:rolleyes:
          1996 Chevrolet Camaro
          1995 Buick Park Avenue Ultra
          --Appearance Moderator--
            On top of what the other members said, also check your u-joints. If they're going then it will cause your driveshaft to vibrate and your rear end to shake. They should be replaced every so often anyways.
              Loose Driveshaft????
                tie rods on their way out could be it also...except that would probably manifest itself more on acceleration, not just over a specific speed...
