how to lower my car - FirebirdV6.com/CamaroV6.com Message Board
how to lower my car
  • #16
    Re: how to lower my car
    take all the air out of your tires, that will lower it.
    • #17
      thats what I do!
      • #18
        Originally posted by Bonemaro View Post
        Let me know how that goes and post pictures.
        Will do!
        • #19
          I also want to lower my car.
          At the minimum i need Springs/shocks and LCA's. Correct?
          -Y87
          Lid,K&N Filter,PaceSetter Headers,Magnaflow Cat 2.5in S-pipe,Flomaster :(,3.42 LSD
          • #20
            Springs and LCA Relocation brackets at minimum.
            Your factory LCA's will be fine. If you just install springs, you will most likely run into a wheel hop issue.
            Aftermarket shocks are highly recommended.
            Lounge Moderator
            • #21
              how much did ur whole set up cost u bone?
              • #22
                Hmm... I forget exactly. Got some good deals. I would guess $700 to $800.
                Lounge Moderator
                • #23
                  :eek:Damnnnnnn. I don't want to spend this amount of money to lower my formula..LMAO
                  • #24
                    I did a lot more that just lower it though.
                    Lounge Moderator
                    • #25
                      yeah all you really need to lower your car are springs, ~$150. He added shocks ~$400, reloc brackets ~$80, and lower control arms ~$100
                      • #26
                        ...and poly ball bushings, poly end links, 32mm front hallow sway bar, 17mm rear sway bar and panhard rod. So yeah, there's a bit going on with the higher budget.
                        Lounge Moderator
                        • #27
                          the stock shocks are the worst part of the whole suspension. and theyre not valved properly for lowering springs.
                          id say new shocks are a must, unless you want it to drive like crap.:slap:
                          <a href=\"http://www.cardomain.com/ride/2265676\" target=\"_blank\">95 bright red camaro 3.4l</a>
                          • #28
                            Yes. One thing I can honestly say about the H&R 2" progressive springs and the AGX shocks combo, my car rides damn near the same as stock during normal driving conditions. The only time I notice anything is when I hit a really big bump (which is stiff, but not horrible) or I really get on it with some high speed maneuvering. Then the suspension locks in and shines like a champ.
                            Lounge Moderator
                            • #29
                              It can't be close to the same.. My car bounces all over the damn place and every other F-body I've been in does the same. The body roll is insane.
                              • #30
                                sounds like its time for new shocks.
                                -Y87
