Is there anything out there for sidewall repair? I backed out of a steep driveway abit too sharp today and my inner fender put a nice gouge in my sidewall. Tire's still holding air, I'm just wondering if there's anything I can do to fix/strengthen it. Tires are BRAND NEW so this is pissing me off.....
Side Wall Repair?
Re: Side Wall Repair?
There is bead tar stuff I got at Napa for fixing leaks, I had some leaks due to the chrome rims I has bought used, the chrome was going bad and I was having to use the bead sealer. You can put some on there and see if that helps, but if it starts to bulge out you need to replace the tire since it is on the sidewall. I also wouldn't be goign high speeds.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Well, it looks like it's just through the rubber; no fibers are broken or anything for what I can tell (it is night, so not entirely sure). Tire is still aired up completely with no bulging from the area or anything, which is why I'm looking to repair it.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
