idk if this should go here or in engine bc i dont know what might be wrong with it. sometimes when i slow down or just stop my car begins to shake or wobble....id like to say it comes from the back of the car but not sure if its from the engine. Anyone know what it could be? pretty sure this has been asked b4 but search was messed up
car wobbles/sways?
Re: car wobbles/sways?
Originally posted by TheGr8Schlotzky View PostWhen you are in the process of slowing down, or when you are stopped?
Yes, more info is needed, could be a bad tranny mount or engine mount if it is at idle, if will stopping could be tires or warped rotors.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by poncho1961 View PostAs asked above, it would help in the diagnosis. If happens when slowing down then as suggested it could be tires or brakes. If happens when stopped, is idle low? Happen only when running A/C or in defrost? Broken motor mount letting engine jump around at low idle. Does it go away if you slightly step on the gas?
Car would'nt continue to wobble after it was stopped if it was the brakes or tires. Not unless it was wobbling so bad it almost knocked you out of the seat when you first stopped. :) I would look at mounts. If it does it in park, pop the hood and watch the engine. Should be a little movement but not alot. It would be a rocking motion. If tranny mount is broken, you may see an end to end sliding motion as well as the rocking motion. Have someone blip the throttle while you watch the engine. A broken motor mount will allow the engine to rock up on the other mount more than it should. The tranny mount would allow for the engine to slide side to side instead of the normal rocking. I would think this would show up under hard acceleration or downshifting tho more than just slowing and stopping.
Originally posted by poncho1961 View PostCar would'nt continue to wobble after it was stopped if it was the brakes or tires. Not unless it was wobbling so bad it almost knocked you out of the seat when you first stopped. :) I would look at mounts. If it does it in park, pop the hood and watch the engine. Should be a little movement but not alot. It would be a rocking motion. If tranny mount is broken, you may see an end to end sliding motion as well as the rocking motion. Have someone blip the throttle while you watch the engine. A broken motor mount will allow the engine to rock up on the other mount more than it should. The tranny mount would allow for the engine to slide side to side instead of the normal rocking. I would think this would show up under hard acceleration or downshifting tho more than just slowing and stopping.
Whats your voltage read when you are stopped? This might be a shot in the dark, but my old grand prix would bog down the engine sometimes when the brake lights were on and it was at low idle and shudder a little. It would especially do it with my headlights on. Infact, I could see my lights flicker brighter when it would shudder. I can't remember if it was my battery or alternator, but they both got replaced eventually.
Good luck2000 White Firebird <br />K&N Filter, Aluminum Driveshaft<br /><br />95 White Firebird - Laid to Rest<br />K&N FIPK, Flowmaster Exhaust, Jet Chip
Just to be safe, check your tie rod ends too. I once got an intermittent wobbling during stopping on an uneven road / turning and took a look at one of the tie rods and it was about ready to fall off. However the wobble happen so infrequently I almost didn't even bother to check thinking it was an alignment issue. The car handles worn parts like a champ, but you might be closer to breakage than you'd think.
Hey guys. For starters I’ve always been a big car guy, I love all types of cars and can appreciate all types of engineering. I’ve always been a Chevy...3 days ago
by ssms5411Getting a massage saying invalid interface, haven’t used it since last year probably November. First time in 23 years I had a problem. Going to get...5 days ago
