I've got a rear sway from a 97 convertible Z, and my dad found a front sway today out of a 94 TA. He says it's bigger then 25mm (biggest wrench he had with him), and feels hollow; chances are this is a 32mm sway, right since it's hollow? Would pair up nicely with my 19mm rear, right?
Sway bars
Re: Sway bars
well, he paid $15 for it and an electric fan for our track car, so if it's not the 32, I won't lose alot of cash. I do have a stocker on the front now, with the Z on the rear. My rear should be a 19mm, right? And any way to tell for sure if this is hollow or solid? (I haven't seen the bar yet, so just asking)~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Sway bars
32mm and 19mm should work well together, I got a deal on mine so I run a ST 35mm front and a 21mm rear with poly bushings(paid $120 for both with bushings etc.) got to love craigslist. The guy had a 02' Camaro and just did autocross only, he went with a all hollow setup for weight savings.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Sway bars
Originally posted by reggie CFH View Postyes it would. Do you have the stocker on the front now? Def. only get it if it is a 32mm. the 30 is a good upgrade but i wish i would've went ahead and got a 32.
If you tap it with a wrench, you should be able to tell if it's hollow or solid. More than likely it's hollow.
Re: Sway bars
do it....I just changed mine to a 32 hollow front....I love it, nice difference...she hugs corners nicely.
yea tap it with the wrench you can tell if its hollow. 30mm is stock, 19mm should be stock on the rear as well....
Re: Sway bars
Originally posted by RadRacer View PostAnd any way to tell for sure if this is hollow or solid? (I haven't seen the bar yet, so just asking)
Cut it in half? you should be able to jb weld it back or something of that nature...
=D2001 Camaro 3.8 A4
1991 3000GT VR4
2001 Mitsubishi Eclipse GS
Re: Sway bars
Just weigh it, solid is going to be more than hollow. There is a weight reduction site I think has it , where they are weighed everything. I know my ST 35mm front is 34lbs.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
