Like it says, I have a hurst line loc I want to install. I just cant figure out what brake lines to tap into between the master cylinder and the ABS Block? I've seen pictures of an SLP one installed, but it just looks too simple.
Need Help Installing Hurst Line Loc
Re: Need Help Installing Hurst Line Loc
did you get just the solenoid, or did you get the pre-bent line kit too? I'd get the lines too if I were you; makes it alot easier, and doesn't require any splicing of brake lines.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
I got the hurst kit that comes with the solenoid, switch, activation light and some odds and ends. There's no pre-bent lines but there are instructions with pictures. The only thing is the kit says that the line loc isn't meant to be installed on a car with ABS. But this is the only one hurst makes. And I've seen them installed before.
I just need to know what lines to tap into, before or after the ABS box.
I just told ya what you need; get the pre-bent line kit for F-bodies. Works with ABS and you don't have to do any splicing or anything.~97 3.8L V6 Camaro~
A few things
Look at thunder racing; it won't be under the V6 section, so look under the V8 section for your year (assuming it's an 02, look under the LS1 section). Go to braking> line lock kits and scroll all the way to the bottom and you'll see a pre-bent brake line kit for $50~97 3.8L V6 Camaro~
A few things
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
