last week, when I installed my "new" rear end, also I changed front pads and resurfaced the rotors, but were so bad, that it had to be done like ten times. before that, i had the typical noise that tells you "well, I got to change those pads".
then, after doing that, I noticed an awful squeeking noise on the right disc brake, at the moment of braking, which I thought was caused by the rotor, because of the bad shape those are. but today, I noticed that the noise can be heard at some points when cornering, without any braking, which makes me think it's something on the bearing but before doing the front brake work, that noise wasn't present.
Can anyone tell me what the hell is going on? I don't think the problem is the bearing, because the noise started after resurfacing rotors and replacing pads, before that, there wasn't any noise, just the one made by old pads.
so it seem as though you have to get a complete rear end or have yours sorted out the flange the holds the rear caliper have the rotors checked and also the axles,the whinning can be coming from in the differential maybe a pinion bearing it all depends on when are you hearing the noise,if on accelerating or decelerating?but deal with one problem at a time if you can.
