Hi I've been looking around and found something quite confusing on steering racks, now they say here in the technical section that 93 models use 16.9:1 ratio,then they say in 1996 the Y87 package is 14.4:1(same ratio as V8 models) then later say that the ratio from 93-01 is 16.9:1,but then they is a 2 3/4 turns lock to lock from the sterring wheel on the F41,then they is a 2 1/4 lock to lock from the steering wheel on the FE2.
Can someone take me out of this maze,I would greatly appreciate it.
lol man I was looking into the same thing as well but its hard to get consistent information out there. Let me know if you get anyone to give you helpful info on this I'm curious on this topic.
All non-Y87 v6's and lt1s used the same steering rack with the 16.9:1 ratio. These use the rag joint coupler. Ls1 and Y87 used the closer ration steering racks, the 14.4:1 ratio. They use the double u-joint design coupler. Although I have read that there may be two different LS1/Y87 ratios, but don't know how to distinguish between them.
'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
All V8's and V6 Y87 cars use the same (quicker, 14.4 vs 16.6 ratio) steering rack.
On my list of things to do.
In short, all V6 cars came with the F41 code (V6 suspension), although Y87 cars came with the quicker ratio steering rack. FE2 was the V8 suspension, which also had the quicker ratio steering rack (with the exception of LT1s).
You can always upgrade to the quicker ratio steering rack and double u-joint coupler. I got the coupler for $3 and a used steering rack from a TA for $45 off of ebay. Install shouldn't be too hard either.
Ok well understand a bit more,so what part number or info or specs on the upgraded joint? I'll buy the 2 1/4 turns from steering wheel @ rockauto,will still do more research on these High Ratio racks and what actually is the F41 and FE2 in terms of what you get in detail.
Thanks for everything so far
A new steering rack from Rock Auto or any retailer is going to cost over $175. You can find a used one for a lot better price from users on LS1tech or even ebay. Remember, it has to be a 98-02 V8 rack, because the LT1 style is the same as the V6.
'99 Camaro
'04 Saab 9-3 Aero
I don't have part numbers. But I can tell you a little more of what I found about F41 & FE2 options. There was also an FE4 option, but that was a V8 only option.
F41 is the V6 suspension, which means that it has the stock decarbon shocks, V6 spring rates, and the 30/17 (93-97) or 28/15 (98-02) sway bars.
FE2 is the V8 standard suspension, which means that it has the stock decarbon shocks, V8 spring rates, and 30/19 sway bars.
FE4 is the heavy duty V8 suspension, which essentially came with the 1LE suspension package; Bilstein HD shocks, 1LE springs, 1LE 32mm front sway bar, 1LE LCAs and panhard bar. These parts also varied throughout the earlier and later years.
Steering rack ratios may have been influenced by these numbers, but I'm not sure of that.
Ok thanks for all the info pace2006,but you see I live in Barbados so can't get a used one because I can't actually see what i am buying,cause they are no large amount of our cars here they are about 5-6 cars of such here 2 C06 Corvettes,one old Corvette one 90 pontiac firebird,one 89 Camaro and mine which is 93 V6,so we do our buying online
Then why do the LT1s use the rag joint style coupler while the LS1s use the double u-joint coupler? I thought there was a 90* difference between the two.
Edit: Nevermind. I found the info. Thanks for correcting my answer.
Some good info in this thread, makes me want to change out my steering now, to see how much of a improvement it makes on turning. Thanks for posting the pics and what parts are needed for the swap.
FirebirdGT first thing is that your firebird in the pics if so I'm so much in love with it,I would swap my camaro and pay extra if needed,I just love those cars,next thing I read your database and the info wasn't quite clear,read back from where I start the post and see what I wrote all I wrote comes from your technical database.
Yes, it's my Bird. Did you look at my site?
What you wrote in your first post is all correct. Nothing I saw in reviewing the TB is incorrect in any way.
The panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...
Has anyone used the zzp gt 1 cam what kind of gains did you get thanks
