Help with traction - FirebirdV6.com/CamaroV6.com Message Board
Help with traction
  • Help with traction
    since i have added all my bolt ons i havent been able to get any traction in first, i even have brand new tires and i still spin all the way through first and some of second, is there any suspension mod that will help this? or will i just need a bigger rim and wider tires
    Re: Help with traction
    Adjustable torque arm and adjustable lower control arms. Then you can put some pinion angle in it. That will help it bite.
      throw in some lca brackets with the control arms to plant those tires down too. then check if you have a posi or not (y87 package is a giveaway, or the "one tire fire" burnout)...mine's running open posi with 3.23's (until i get a decent posi and gears) and i can't hook for sh*t.
      pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
      gone in body, but not in spirit
        not trying to be rude but there is no such thing as an open posi there is an open rear which you have...
        2001 Camaro 3.8 A4
        1991 3000GT VR4
        2001 Mitsubishi Eclipse GS
          6 one, half a dozen the other...
          and actually yes i've heard of my "open rear" referred to as an open posi, which is just a lack thereof...either way, it doesn't help the OP worrying about it.
            get a posi if you dont already have it
              ^ LCA's, tunnel mount TQ arm,3.73 gears with Torsen diff, etc. , 275/40/17 bfg tires and no spin or loss of traction with mine, thats even with a shift kit and 100 shot of nitrous, just chirps 2nd and 3rd gear.
                alright, ill get some lca and see if that helps,
                  no offense but posi is not reffered to an open diff,our diffs arn't even posi,their LSD,posi is what some true dragsters have to produce 100% of power to both wheels,but yeah if you have open 3.23 you will definitely spin,i had 3.08's with mild boltons and i spun through 1st like a mofo,your best bet would be getting it LSD or 3.42 LSD.
                    Originally posted by Richardcoelho View Post
                    no offense but posi is not reffered to an open diff,our diffs arn't even posi,their LSD,posi is what some true dragsters have to produce 100% of power to both wheels,.
                    um....NO.
                    http://en.wikipedia.org/wiki/Limited_slip_differential
                    Quote from above Wikipedia link.
                    In the 1950s and 1960s many manufacturers began to apply brand names to their LSD units. While Packard pioneered the LSD under the brand name "Twin Traction" in 1956, the most famous of these was Chevrolet's "Positraction". Since then, Positraction (often shortened to "positrac" or merely "posi") has become a genericized trademark for LSDs.
                    Other factory names for LSDs include:
                    * Alfa Romeo: Q2
                    * American Motors: Twin-Grip
                    * Buick: Positive Traction
                    * Chevrolet/GMC trucks (after 1973): Gov-Lock
                    * Ferrari: E-Diff
                    * Fiat: Viscodrive
                    * Ford: Equa-Lock and Traction-Lok
                    * International: Trak-Lok or Powr-Lok
                    * Jeep: Trac-Lok (clutch-type mechanical) and Tru-Lok (gear-type mechanical)
                    * Mopar: Sure Grip
                    * Oldsmobile: Anti-Spin
                    * Pontiac: Safe-T-Track
                    * TVR: Hydratrak
                      are you on ice?
                      Archer
                      MISC: 01 parts. Some interior, T top kit, seats etc.
                      http://forum.camarov6.com/showthread.php?t=95347
                        thank you, bigbrian
                          posi and lsd are the same thing
                          i think you are thinking of a locker rear end, where both wheels get the same power all of the time.. ONLY except if you are going around bends it will unlock
                            You need this.
                            http://forum.camarov6.com/showthread.php?t=94675
                            http://www.cambirdracing.com/photo_a...76844/54150/1/
                              if you need some suspension goodies, I suggest some UMI lcas from gvperformance.com :D
                              Or if you are looking for a single adj. LCA, I have a brand new set still wrapped up from UMI I will let go for $165 shipped
                              http://www.bowtiev6.com/
