what is the widest tire i could fit on a stock 16x8 wheel?
tires
Re: tires
Originally posted by 3800v6 View Posthate to say this but, i have no clue what arbitrary means..
Re: tires
Originally posted by f-tothe-ill View PostDude, this is the internet, look it up. http://tinyurl.com/b2zv7v
Re: tires
3800v6,
I would say a 255 is probably the largest, but each tire fits a range of rims. Log onto the www.tirerack.com and pick the tire you want. Then click on the specs. A chart will come up with the specs on all the different size tires under that specific tire. The chart also contains a suggested rim size. For example a BFG G force Sport tire in 255/50/16 recommends a rim size between 7-9 inches.69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
Re: tires
Tirerack is a good place to start. I work at Belle Tire (major tire vendor in michigan and ohio) so if there's one thing I know, It's tires.
For a v6 camaro you're not going to need anything above 245 on stock rims. 255 will create alot of drag and will definitely decrease your fuel economy.
Here are your sizes
245/50R16
235/55R16
225/60R16
My brother has 225/60R16's on his Z/28 and they grip just fine. I have 235/55R16's on my 3.4 and they cant find traction anywhere (probably because they're almost bare.) My point being that it's not so much about how wide your tire is but how grippy the tread compound is.
I noticed that you live in AZ. If so go with Ultra High Performance Summer Tires. Tirerack has alot of good recomendations and reviews. If you're looking to save some bucks go with Kelly Fierce UHP's. They're made by goodyear and their really really nice for a good price. Just remember with any UHP tire they wont last more than 30,000 miles. A good compromise might be High Performance All Season tires. Once you scout out the tires you're considering post back here. Chances are I know a bit about them.
Re: tires
Originally posted by Den69RS96 View Post3800v6,
I would say a 255 is probably the largest, but each tire fits a range of rims. Log onto the www.tirerack.com and pick the tire you want. Then click on the specs. A chart will come up with the specs on all the different size tires under that specific tire. The chart also contains a suggested rim size. For example a BFG G force Sport tire in 255/50/16 recommends a rim size between 7-9 inches.Originally posted by Bugsy View PostTirerack is a good place to start. I work at Belle Tire (major tire vendor in michigan and ohio) so if there's one thing I know, It's tires.
Here are your sizes
245/50R16
235/55R16
225/60R16
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
