opinions on swaybars - FirebirdV6.com/CamaroV6.com Message Board
  • opinions on swaybars
    Basically I want to get some feedback from you guys on the biggest sway bar setup that would be beneficial and still safe to use on my setup. I've ran across a great deal on a 34mm front bar and a 24mm hollow rear bar, will this be too much with eibach springs, kyb shocks, adj panhard, and (soon to come) adj lca's & brackets with 18" z06 rims? She's a 2002 m5 ttop.
    I know it's an endless debate, and yes, i've done countless searches on swaybar sizes and all the rants and raves, but I wanted to get some respectable opinions on my specific setup and see what you guys advise...
    pacesetters|full 3" borla exhaust|3" stainless e-cutout|slp cai & ram intake|c/f whisper lid|tbs|eibach|kyb|stb|sfc's|adj.lca's & phb|slp fan|b&m t5|180*|z06 17x9.5|8000k hids|hptuners|d/s rotors
    gone in body, but not in spirit
    Re: opinions on swaybars
    I've got a hollow 32mm front sway bar up front, but am still running the stock 15mm rear. I don't know too much about spring rates and swaybar sizes, but typically what I've heard is most people go with a 19mm rear. Too big in the back and it will be similar to running a slightly larger than stock rear sway with stock springs; it can be unsafe.
    You might be able to talk with Sam Strano. He's more of an LS1 guru, but he still knows some about these v6 cars. He sells a 35/25 combo, and might be able to give you some advice.
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
      24mm is TOO large for the rear. I run 35/19.
      Raven
        would a 34/21 be a balanced setup? i've always heard 32/19 is a pretty sweet pairing but would a step up (34/21) on each end be overkill?
        firebird--how do you like your setup compared to stock?
          I run a ST 35mm front with a 21mm rear and it responds very well. With every other suspension mod on it.
            I run a 1LE set up 32/19....i love it
