springs and shocks yes...and while you are in there, look to see if the bumpstops are broken...should be visible when you take off the wheel...replace them if they are...
sounds like your bump stops are worn or corroded down and your hitting the bottom of the car body with the axle.
Archer.
yep...I had the same problem...my springs were worn out, and I had replaced the shocks alone and that didnt fix it...when I replaced both it fixed the problem...I still need to put in my new bumpstops...
