i know they used different brakes in the ls1's than the v6 (or at least thats what i heave heard) but are the back calipers the same?
ls1 brakes
Re: ls1 brakes
I think the calipers are different,
arnt they aluminum, v6 are steel?
But this is an interesting question, and I should of used the search tab...
to update the braking system, you need the LS1 spindles, rotors, calipers, I believe the hub bearings are the same...
Course the C5 calipers are going at a decent price on ebay right now, so slap on a bracket and roll with it.. lolMISC: 01 parts. Some interior, T top kit, seats etc.
http://forum.camarov6.com/showthread.php?t=95347
Re: ls1 brakes
Q: Why is this brake setup called “LS1” brakes?
A: It is a lot easier to type LS1 instead of “98+ Camaro/Firebird”. In 1998 GM introduced the LS1 engine into the F-bodies that same year they also put bigger brakes and a few other goodies. I am just using LS1 as an easy way to identify the 12-inch, dual piston caliper brake setup on these cars. It is important to note that the "LS1" brakes also came on the V6 98+ Camaro / Firebirds also.
Re: ls1 brakes
Originally posted by cam98aro View Postok, after doing some searching, i have come to the conclusion that ALL brakes on 98+ camaros are the exact same, whether it was a v6 or v8
can anyone confirm this?
Originally posted by FirebirdGT View PostOK, time to fix the BAD info! :spank:
ALL 93-97 V6 and V8 have the SAME front brakes - single piston.
ONLY the V8 and Y87 V6 have rear discs.
ALL 98-02 V8 and V6 have the same front and rear brakes - front 2-piston, rear single piston.
Read the Tech Database!
I have installed the 93-97 rear discs (replaced drums) and the 98+ front brakes on my Bird.
.'99 Camaro
'04 Saab 9-3 Aero
'90 Audi Coupe Quattro
Re: ls1 brakes
^Thanks bud, so to install the C5, i just need the brackets.. so the spindals are the same.. crazy..MISC: 01 parts. Some interior, T top kit, seats etc.
Re: ls1 brakes
Originally posted by Archer View Post^Thanks bud, so to install the C5, i just need the brackets.. so the spindals are the same.. crazy..Last edited by pace2006; 03-26-2009, 05:15 PM.'99 Camaro
'04 Saab 9-3 Aero
Re: ls1 brakes
What an improvement over the 93-97 cars:bowdown:
