I gots the clunk - FirebirdV6.com/CamaroV6.com Message Board
I gots the clunk
  • I gots the clunk
    3.4l 1994 camaro. So I've had this clunking front passenger ever since I put my new shocks and springs on, today i lifted it up and took a look, I put weight on the lower arm and everything. Nothing seemed amiss, but my sway bar has looked like this for well, a long time, could that be my problem, I can get a little noise out of it, I have all new tie rod ends, inner and outer.
    Re: I gots the clunk
    does it happen when you go over bumps, if so try rocking the car side to side while standing outside the car. if you hear it there i would bet it would be you frame mount sway bar bushings. or it could also be control arm bushings.
      Well, I actually had an Idea, so I went outside, and watched each part as I jacked it up, and as the shock and spring were lifted, it looked like the top nut on the shock isn't all the way secure, and there was like a cm of travel before the shock started to compress, anyone else ever done this? And could it have caused damage to anything?
        It's probably just that the bolt is loose. Tighten it down and see if that fixes it.
          yah tighten that upper botl down. i did the same thing. have fun compressing those springs over. I became a master at it after it was all said and done.
