abs inop light? - FirebirdV6.com/CamaroV6.com Message Board
abs inop light?
  • abs inop light?
    finally got my car back together, started it up, & it hasnt really had brakes! the brake pedal is up, & it wont go down too far, maybe an inch or 2, also, the e-brake wont go up & connect/work at all. cranked the car up today, & the abs inop light came on & stayed. any ideas y the light would come on?
    Re: abs inop light?
    it usually comes on when the car cant read the wheel speed sensors.. or the wheel speed sensors are getting weird readings (such as you spinning the tires in snow, backs are moving at 60mph, while fronts are going 5mph) and a bad 3rd brake light on older cars can cause it
    what exactly did you do to the car when this problem started?? replace the back brakes?
      Re: abs inop light?
      i just got the car running on friday, cranked it up, while it was sitting on some ramps, i noticed it then! so today i took it off the ramps, but the battery was dead, got it charging now, will start the car tomorrow or wednesday, after i put a new plenum gasket on it, & see if it being off the ramps will make the light go off! i havent touched the brakes yet, just trying to get it running right 1st, then the light pops on, so i figured ild ask about it! its a 95 camaro, 5 spd car, if that helps any!
        Re: abs inop light?
        Yeah, start with the easy stuff. Put your foot on the brake and have someone check to make sure your spoiler brake light is coming on. If it is burnt out, it will trigger the ABS inop light.
        Then try cleaning off the wheel speed sensors. Start there and get back whether it's still on or not.
        1996 Chevrolet Camaro
        1995 Buick Park Avenue Ultra
        --Appearance Moderator--
          Re: abs inop light?
          cool guys thanks! ill try this in the next day or so!
            Re: abs inop light?
            where are the wheel speed sensors? my my abs inop/ebrake/low trac/airbag light love to flash sometimes.
              Re: abs inop light?
              anyone?
                Re: abs inop light?
                My ABS light is on too but the brakes are working fine what else could it be?
